[H]elp - Strange Video Problem
Useness
My problem is this, upon restarting my computer for whatever reason, my monitor fails to turn on. It appears that my computer is booting normally. However I can't confirm because my monitor stays inactive.
For Reference:
Monitor Power Light when Idle, Blinks
Monitor Power Light when Active, Solid
Monitor Power Light when no power, Off
For some reason I have to restart my computer 2-3 times on average before my monitor will turn on with the computer.
Once the restarts spark the monitor I have no issues for days, weeks, etc, until I either have to restart or I attempt to play a graphics intense game. Then I will randomly lose video and my comp locks up...
Any help you can toss my way would be most appreciated.
Monitor:
Dell 19"
Vid Card: Nvidia GeForce 6800 GT 256MB (Driver Ver. 6.14.0010.9371)
Mobo: ASUS A8V-Deluxe
Processor: AMD Athlon 64 3800+
OS: Windows XP Pro
Some odd things of note.
I have all this in a Lian Li case, which I erroneously bought for merits of being 'sound proofed' What I didn't realize at the time of purchase that what sound proofing translates to is heat insulation... So when playing games such as HL2 or NWN2 I am forced to open my case for increase airflow to avoid what I believe is an over heat issue. I believe this to be the cause because I can only play the game for about 3-7 mins before my monitor goes IDLE and I lose Video, Audio continues for a shortwhile before the comp locks up. I've only gotten one BSOD from this and it cited a obscure code, possible related to a boot sector virus. AVG Anti Virus detects no threat.
Also my Video card was shipped slightly askew on it's mounting bracket, which doesn't allow for a smooth fit into the AGP slot. It will seat fully but it seems straining.
Leave the side off and set a fan blowing in there to ensure it is not a heat issue.
That's my new routine now :D Otherwise... no gaming for me
But doesn't solve my strange issue
Well first I would solve that problem as it is likely to be related. :p
It's not a boot sector virus.
My money is on a video card giving up. If it doesn't fit in the slot correctly, that can be a problem, and to me it seems pretty obvious that heat is the actual source of the problem.. You may get a few more miles out of that card if you can come up with a cooling solution that works... but I don't think that card has got much left in it... Good luck.
Well that sounds unfortunate...
Looks like I'll be in the market for a new vid card then. :mad:
What would be a good upgrade for the MOBO? A8V-Deluxe
If heat is killing your GPU it's also likely to be killing your PSU...
As for motherboard replacements (I take it you're building a whole new machine now?) Gigabyte P35C-DS3R or the equivalent in the DQ6 line (if you want all solid caps), or an EVGA 680i board if you want SLI.
If you want a new case that's quiet and won't kill your components for heat, a P180/182 is a good option. You should be able to get one for around $80 after rebate. Add another $15-20 for new fans, though. 3 or 4 Yate Loons at $4-5 a piece move more air than the TriCools that come with it, and they're quieter.
My 7900GT Does the same thing. Instead of restarting, powering the machine completely off for a couple seconds, then turning it back on does the trick every time. Of course I also have problems with my CMOS being reset every time I power off my PC but not when I reboot....it's odd.
I really hope this isn't a sign of a video card failing...I have noticed occasional artifacts in BF2142, but I was attributing it to game glitches since that game is notorious for them. It is a lot warmer here lately though, so if it's the same problem then the point of temperature damaging it is very valid.
