Not really. You can even get non-RAID drive controllers with heatsinks.A heatsink is usually a good indicator. If it is using more power than a dumb sata controller, it must be doing something with it.You'll see it in the price as well. If its a new 4 port card, and its under ~$250, its probably no better than your onboard ports.
Hardware RAID cards have RAM though. You'll either see chips on the card or a socket for it.
