[H]ard|Folding (Graph Problem Fixed)
King_N
[H]ard|DCer of the Year 2007
Since the server upgrade, [H]ard|Folding has had a problem with the graph package, the package itself is not compatible with the new hardware/software, I'm sorry I can't go into more details then that.
I installed temporary graphs to make things a bit nicer during this time.
Since this issue the [H] server admin and I have wracked our brains trying to figure out a solution to the problem and I'm happy to announce that we found one, as of this post the F@H stats have the normal graph package running once again. (The [H] server admin really worked his tail off to help us out here and I definitely appreciate the help getting this issue resolved.)
I'm still putting some finishing touches on the F@H graph areas and then I have to move on to the other areas site wide.
The graphs available again are (Bar, Line, Trend [with confidence], and Pie)
I had to recode the graphs and I did so in a hurry, hoping to get everything back to normal as fast as I could, please let me know if you run across any bugs.
1 [H]ard Team, 2 Great Projects, 1 Common Goal..... The Cure.
Site Admin: [H]ard|Folding
Lurker Extraordinaire
All graphs site wide should now be operating again.
Hmm really hard to read how things are working, have there been any problems?
Everything seems to be in working order on my side, although I've a question for you, about the legends on the graphs, sometimes they can get in the way, not that I do not need to see the graphs but that's kinda pointless to have the legend in the way of the graph at some point.
Everything else looks great and I thank you for all of your hard work.
Not sure what you mean, the legends should all be outside of the graphs.
Could you please give me a link to the page where the graphs are having this problem?
My apologizes, I didn't noticed that you have changed the graphs... Not too long ago, they were all broken and then there were graphs up with legends on the graphs and now we're getting the old ones that we used to have and they do work. :) Sorry for the confusion, I should have checked the site more carefully, but I don't see the pie graph anywhere only the line and bar ones.
Thank you for your hard work once again.
There are bar, line, trend, and pie.
The 4 are available in the following areas.
1] Overall Project Graphs
2] Overall Member Graphs
3] Team Graphs
3] Team Member Graphs
Pie only charts are available in these areas.
1] Overall Member Percentage Page (Member Selected)
2] Team Percentage Page(Team Selected)
3] Team Member Percentage Page (Member Selected)
Bar and Line only charts are available in these areas
1] Overall Member Attack / Threat Member Comparison
2] Team Attack / Threat Team Comparison
3] Team Member Attack / Threat Comparison
I just noticed the pie charts in a couple areas are having an issue, I will get started on a fix for that.
Issue should be remedied now.
Hrmmm, now that is a seriously weird issue, thank you for bringing it up.
I will look into it.
Ok the issue has been located, it's source is the *needless* messing with the DST that was *supposed* to save fuel but did nothing.
Since stanford didn't update their clocks and the [H] server did I was forced to write a fix. Normally stanford and the [H] server remain 2 hours apart, but when this change took effect it was raised to 3 hours.
04-01 was the normal clock change time, when this took effect the servers were once again 2 hours apart, which I had coded for.
What I didn't see happening is the server upgrade and the charts refusing to work, when that fix was put into place the 04-01 date became 03-31 because the fix didn't take into account for the needless messing around with DST.
Anyway to make a long story short(I know, TOO LATE!)
I am re-writing the code to take into account the fix, of the fix, of the fix, that stemmed from the needless messing with something that shouldn't have been messed with in the first place.
It's going to take me a while but it will be fixed.
When was the last time our legislature did something productive?
(great movie reference, BTW. Particularly well-executed in Clue)
Thinking..........????????.....
Was wondering if anyone would catch that referance..lol
I do however prefer Murder by Death (1976) over Clue, but Clue is good too.
Ok the date issue should be resolved.
So far so good for me, Thanks again King for all your time and [H] work on the project. Also thanks to the behind the scenes [H] admin
I'm not sure if this is a feature I just don't understand, or an actual bug. It is time related, but no idea if it is related to the other problems.
If you look at William_L_Moore on my threat list, he is in both the 90 days or less and the 30 days or less categories. I'm thinking he should only be in one, otherwise enigma1983 would be in the 30 days, 90 days, and 180 days categories.
Looks like a bug, thank you for pointing it out, it should be fixed now.
Have there been any other problems?
