H.264 playback on Intel T2310 CPU Utilization - Does it Skip?
mage333
I think the title explains it all. I'm interested in getting a laptop. The model I'm looking at has an Intel Centrino C2D T2310 processor. The most CPU intensive task I will do is video playback. The file format I mainly use is H.264 in 720 video resolution, using the MainConcept codec. However, I may choose to output 1080 to my TV.
Does anybody here also have a T2310 that they use for video playback? If you do, can you tell me, does it skip during playback of either 720 or 1080?
THat cpu should be fine, i have used my T2500 at different speeds to test out 1080 capability. I wasn't using the codec you were but i was able to watch videos while running @ 1.3ghz. So you should be fine
