GUIDE: What CPU cooler should I buy?
Status
Not open for further replies.
I'm looking at coolers for an Athlon 64 3000 venice, I want to do some overclocking but I also want some quiet. I want to put it into an Aspire X-QPack which has a structural bar that limits my cooler choices to anything below roughly 80mm in height (I don't feel like modding to compromise the structural integrity of the case). So far the only legit cooler that fits my criteria would be a Zalman 7000B, is there anything else that you can think of that would do the trick, while staying pretty quiet?
Zalman 7700Cu (Yes it's Big and Heavy but it's great for cooling at a low fan speed).
And it cools all the other stuff around it.
Thanks Tiny, added! I'm also going to add a listing on thermal compounds and recommended fans.
The Scythe is more of a special heatsink... being mostly passive, users will need to take case ventatilation into consideration. The solutions I've posted up are more conventional solutions for more conventional people. ;)
Solar, the AC Silencer 64 Ultra TC L is 77mm in height. It'll be quiet, that's for sure, but the Zalmans may offer better performance (though for significantly more money).
I'll think I'll stick to Zalman while the 7700 may do the trick I don't think its peformnce is that much of an increase to warrant its purchase over a 7000B.
thanks for the great info! just ordered a Freezer 64 and hoping to get some Nexus fans soon. :D
Status
