guide to custom made reservoirs
.xXLucidXx.
can somneone post like some tutorials or what not about making there own res?
i know deviance has some sweet ones ited be nice if i could get some info?
thanks guys
lol, that's defyant.
as for making you're own, i don't believe there are any good tutorials out there, though if this stays on the front page long enough someone will probably write one up for you.
sorry i couldnt remember the name
but defyant does some great work, i have pm'd him a while back but no response
hopefully he will see this
What kind of rez do you want to make and out of what material?
What kind of tools do you have access to and how accomplished a craftsman are you?
ied like to have one of the tube style res. that defyant has made
not very large around 6-7 inches in height and about 2-3 inches in diameter
the tools i have to work with are common garage tools, dremel roto zip various drills
taps, vice's for holding things mounted on a work bench that type of thing and a very large work space indoors
i was thinking if there was a place to find the tube style plexi glass it would be fairly easy to take some plexis glass and epoxy the ends on it and drill an tap the in-out ports
no machine equipment or anything like that tho
fire up your local yellow pages.
i can get most any form of glass or plastic from a local store called guelph glass that provides both builders and artists with those sorts of materials.
since guelph is pretty small, i would imagine that any reasonably sized city would have such a store.
and, just off hand, i'm pretty sure that you want to use a plastic cement, rather than epoxy. getting total fusion between the two pieces of plastic that you are working with is preferable to haveing a wad of epoxy sticking the two together.
Sounds like what I just built...
Although I have lathes and could turn the endcaps, a flat plate would have worked as well.
Total material cost was under $10.
Look in your YellowPages for "plastic supplies-tube/sheet" or plastic fabricators.
The store I found sells scrap/cutoffs ( which was what I used) for $1.50/lb.
It's actually quite easy to build, so good luck.
