I'm having some trouble deciding between these two cards, perhaps someone can give me some input.
I have 3 24" monitors running off a Radeon 5870 which is really showing it's age now.
I'm not too concerned about the price, but I should probably factor it in, this is what I have so far:
Generally the GTX680 is $100 - $150 more than the Radeon
There is no Phys-x on AMD
The Radeon has a larger frame buffer but benchmarking shows very little difference between the GTX680 and the Radeon at multi screen resolutions + AA
The GTX680 has lower power usage (can I assume that it will be cooler and quieter too?)
Adaptive v-sync on the GTX680 (this is one feature I particularly want, I think it will make a big difference when the card is 2 + years old running future games). But I don't think this make much difference at all with current games...
The GTX680 can run 3 non displayport monitors at once (2 DVI +1 HDMI) this is a big plus for me, I find the displayport adapters to be very slow when changing resolutions or even just starting up the computer.
On the flip side though, there is a 7970 that can run 6 displays (2 DVI + 4 Displayport) that is still $150 cheaper than the GTX680
And finally, I have been loyal to ATI/AMD for almost a decade, I'm quite familiar with drivers and features, so the GTX680 will be somewhat unfamiliar to me, but I'm not overly concerned about it.
I'm still torn, please help.
