GTX570 SLI
loxety
I have the gtx570 in sli, which gtx 700 series card is equal? I only game at 1920x1080.
This is my results from running 3d mark11
P9625 with NVIDIA GeForce GTX 570(2x) and Intel Core i7-4770K
Graphics Score
10642
Physics Score
7463
Combined Score
7511
770 would be about equal. Of course, you get the benefit of more VRAM and way less power draw. :)
Yeah 770 would be about the same but at this point I would go 780 if you can find a deal. Of course the rest of your specs matter too.
GTX 780 would be a great choice. With that CPU it can run almost every game out there with max settings and low-to-moderate levels of AA at 1080p for 60-100 FPS. With a GTX 770 you'll probably have to compromise in some areas to maintain high framerates.
true
I went from 570s in SLI to a 780 and it's been great. Better performance in general and a significant reduction in power consumption and heat output. I game at 2560x1440 so it's only likely to be better at 1080.
