GTX460 SLI temperature issue
alexrud
I'm running a pair of Gigabyte 460's in SLI on an Asus gampage III Gene mATX board. The cooler for both the cards is the dual fan style that dumps the air into the case. At idle my temps are around 38C for the top card and 28C on the bottom one. At full load, however, the temperature delta can get to be as much as 25C! Granted, the temps are only ~75C/52C, give or take - within normal operating temps - so i'm not too worried about overheating.
I do understand all the reasons why it is happening. I've searched the forums looking for a solution to the issue but haven't found anything satisfactory. Has anyone had any success in reducing the temp delta between their cards? I had a bit of luck pointing a fan at the 1/4" space between the cards, but it didn't do all that much. My case has adequate airflow 140 & 120mm fan intakes, and 120mm/140mm exhaust.
Perhaps there is not enough heat venting out of your case. Looking at your case it has a intake fan in the front bottom, What I'd do,(in case it wasn't already set up this way) is make sure that the back and top case fans are set to exhaust air from the case. The back one would blow the air back toward the front before it's exhausted so make sure that is all good and they are both set to exhaust.
Besides that I see only 2 pcie slots on your motherboard and they seem spaced apart enough. What I would say there is to make sure that the power cables that are going to the cards come straight from your power supply and are not daisy chained to anything else. Since it's modular, come straight out of the psu and go in with the connections straight into the cards. (not sure if XFX supplies enough cables) in the packaqe. Edit, nevermind just noticed your psu have 4 vga connectors standard
I see that the intake fans are blocked by the HD cage reducing the air pressure. Zip-tieing a 120 mm fan to the HD cage would increase air circulation and could bring temps down. :)
Update...
I decided to pull my motherboard out to apply some new AS5 under the Northbridge/IOH cooler, as the stuff Asus had under there had the idle temps in the upper 60's/low 70's. New temps are high 50's/low 60's, and with a 40mm fan on the heatsink i'm at ~51C.
In any event, due to the motherboard removal I had to remove/reinstall both of my 460's. As I was installing them I decided to put the top card in the bottom slot, and vice versa. To my surprise, the cards are right now idle at 33C top/30C bottom, and at load the temps are never more than 10-12C apart. I'm not exactly sure why this is, but it's better than before. I'll take it :)
Looks like the heat produced by your Northbridge was being dumped into the air intake of your bottom video card. Congrats on fixing it.
