GTX280 GPU-Z screenshot.
People had been throwing around 550 to 576 so its on the high end, so surprise really.
*Rips 8800GT from computer and puts it in the For Sale section* ;)
Looks like an awesome card. Just wish I had a few hundred more dollars to get it though. :eek:
...notice the die size indicated, a bit bigger then what was being talked about.
576 was the most common number that was being mentioned. Keep in mind that GPU-Z doesn't actually measure the size of the die, it has a database of cores with official sizes- don't assume that 576 is right, it's based off the same rumours you and I have heard.
Here's a GPU-Z screen shot for the GTX 280:
Look at the memory bandwidth! Over twice that of a 9800 GX2. Gosh I hope two of these spank Crysis's ass and make it cry!:D
How is the GTX260 going to compare, will it be worth the step up from my 8800GTX I have? Any screen shots of the GTX260 or GPU-Z info?
Hopefully it should be a nice upgrade from the GTX... maybe we'll actually have a new top end card for the first time in a couple years :rolleyes:
Looking at specs it should be worthy update:
Around two times higher shader and texture performance + 30% wider memory bandwidht + 16.666..% more vram. Also GTX 260 should have smaller power consumption (in any realistic situation) than 8800 GTX [if GTX 280 should use around 147W on 3dMark06 when 8800 GTX uses 132W..]
So yes, you should notice slight increase in performance :p
Wow, 240 shaders. That's nearly doubled vs ATI increasing shader count by only 50%.
I love those numbers, the only drawback would be the estimated TDP and the fact that I have an older OCZ 700W PSU which only has 2x6 pin PCI power connectors :(. Stepping up from an 9800GTX and getting a new PSU would be a bit pricey, also if indeed a new die shrink is in the offing a few months from now it's gonna really suck as my EVGA step up expires Aug5.
Power consumption shouldn't be too big problem since it's realistic max power consumption should be around 15W smaller than HD2900 XT's and 30-40W smaller than 9800GX2 or HD3870 X2.
..but that connetor thingy is problematic. 2x6pin connectors should give enough power, but they like to play it safe :S. I mean 3dMark06-load will be that low that theoretically it wouldn't even need any power connectors [assuming that PCIe 2.0 lane would push 150W to GTX 280..like they should].
Can you step up to GTX 260 (Don't know how that system works)? It will have 2x6pin connectors. Or you can try to fid those adapters [4xMolex -> 8pin connector]..
In doing some pondering I will probably upgrade to a whole new PSU with the ability to do SLI, considering that my current PSU only has 2x6 PCIe connectors and 700W, SLI would be impossible. I always try to "futureproof" my purchases, as much as you can futureproof anything in the computer arena. I thought 700W would be ample at the time I purchased the PSU (only 2 years ago!) but then things moved a lot faster and changed a lot more quickly then I anticipated(for instance 8 pin PCIe power connectors).
I'll probably go with the Thermatake 1200W PSU which has plenty of overhead(yeah, famous last words) for at least the next few years. ;)
As for the 260, don't get me wrong it's a good card but I've never been a fan of buying a gimped product where it's only 7/8th capable and wasn't designed that way(i.e then turn off 1/8th of the multiprocessors etc) I can understand binning but crippling a perfectly good chip is like getting a vasectomy, not something I want to understand :D
I especially like the 512 bit memory bus and the high bandwidth, thank you NVIDIA for not screwing around with us like they did for the 9800 GTX.
Now for the benchmarks, we've seen enough of the specs already.
QFT. I don't think memory bandwidth will be a bottleneck at high resolutions like with the most current cards (9800GTX, 8800GT, etc.)
