GTX260 Overclocking
Doggeh
Hey guys,
I've been overclocking my GTX260 from its stock core/memory/shader freq's of 576/999/1242 MHz respectively and I've got to 775/1325/1661 running 100% tested & stable.
3DMark Vantage score of X5371 (X4483 stock)
3DMark06 score of 17924
Temps are 28deg idle, 34deg max full load (obviously water cooled!) using an EK full cover block.
Anyone else out there been overclocking their 260's? I'd like to know what other people have achieved.
Cheers,
Doggeh
wow, thats the highest ive seen on a 260...sure its stable?
Edit....Ah watercooled.. nvm
its definitely stable - vantage runs, play Crysis for hours at a time and the rest of the day its folding non-stop (which is also MUCH more productive now) :)
damn, my next pc has to be watercooled for sure.. the things people push to.. wow
Wow, that is an amazing overclock. I just ordered an MSI GTX260 OC. Wasn't planning on oc until now.
This card has been just great!! All on stock cooling!!
I do however pump good cold air through the system
Air-conditioned air in summer and outside cold air in winter:D
This card kicks ass when you run it with an insane e8400!!
Asus P5E Mobo and G.Skill 6400HZ memory
A truly amazing set up. The card games just fine Thankyou.. All settings high!!!
WZ
Uh well that score of 62,xxx on 3Do3 is obsolete better update....
There now that's much better!!
WZ
WeldZilla, let me know when that E8400 dies or get crippled!!! Insane voltage!
E8400 processors ..... Both have been running at insane clocks and volts since January 2008 ...No degradation at all!!..... NONE I have nothing to worry about and neither does anyone else!!
WZ
