So I have been at this for a while now, reading every thing I could find. Right now I'm running an MSI Lightning GTX 680 witch is based on the Kepler and has 256 Bit bus width and 192 GB/s of bandwidth. It also supports anything form CUDA to OpenCL, DirectCompute etc.
As a CGI artist I use 3DS Max, VRay and Photoshop, but I'm starting to look at Octane and using Fusion 7. I've also bought a new screen, the ASUS PA279Q. Despite the bad things I've read about the screen, it is amazing, at least compared to my old 6bit TFT panel.
So I started to look at some Quadro cards and found out that 3DS Max uses Nitrous Direct3D 11 and the specific drivers on Quadro are old and not working well. As for Photoshop CC it seams to use OpenGL rather than CUDA. On the other hand, Octane only runs on Nvida because it uses CUDA and prefers GTX cards.
So the question at hand is if there is really a point in buying a Quadro. The only issue I have right now is not being able to us 10bit color depth since that is a feature only on Pro cards. This would only be visible in Photoshop or Fusion when editing and maybe in VRay, but I'm not sure.
I also read that Quadro do outperform GTX cards because of specific drivers, but the drivers are spears. Most of them are dependent on the model of Quadro you have and even then Photoshop CC or Max 2014 don't seam to be on the list. This changes with AMD, so I have taken a look at their cards and found that a W5000 is not to expensive. I also compared my GTX680 and the equivalent would be a W7000.
So, should I upgrade to Quadro/AMD? and even if I do, would a cheaper model do the trick just to get some Pro features and use the GTX for anything else.
