GTX Titan Question
jwl24
Does anyone happen to know if 1 GTX Titan ports will allow you to have 2x or even 3x Asus VG248QE connected in surround? I know the monitor has a DL connector, as well as a display port, but the listed options says that the titans port is DL dvi-d and dl dvi-i , can both of those ports be used for the dl-dvi-d ports from the asus monitors?
Thanks for the help.
It should work fine, the Titan supports 3D vision surround +1 on a single card, so it has to be able to do 3x120hz. Using both DVI and the DP should get you what you want.
Alright, just ordered a titan about an hour ago when 1 came into stock on newegg. I think it was the only one since afterwards it went back on auto-notify.
Thanks!
Thanks!
Nice, post back with results. I love my Titan, but I'm only on a single 2560x1600.
