The price difference between a 980ti and a 970 is more than 300 bucks. If you factor in the resale value of your 750 and the mainboard, you could upgrade your rig to a 4790k and board if you settle for the 970.
So the question is which performs better
1) Core i5 750 @4ghz + 980Ti
2) Core i7 4790k @4.5ghz + 970
People throw around the word "bottleneck" too loosely, in my opinion. A 980ti will be faster than a 970, even on your system. So there's no true bottleneck.
You guys are making me upgrade my old CPU
Running an old trusty i7-860 @ 4.0GHZ with a GTX-680. I want to get the 980Ti but I wonder if I should think on upgrading my CPU as I'm moving from 1080p 23" monitor to a 27" one (Probably the new Acer Predator 27").
uh... a lot, even with a 4K monitor.. how much exactly? depend on the game..
Exactly the opposite at 4k.... what are you smoking. HIgher res = vastly less likely to run into cpu bottlenecks.
never said the opposite.. just said that even at 4K his CPU will bottleneck a 980TI.. that's all smart guy..
Depends on the game. Plenty around where 4k with high settings won't maintain 60fps on high settings while the CPU is more than capable of it. You're either grossly underestimating the CPU and/or the demands of 4K, or vastly over-estimating the capabilities of the 980Ti
http://www.anandtech.com/show/7120/some-quick-gaming-numbers-at-4k-max-settings
This is an older article, but a 980Ti is not more powerful than 3 or 4 original Titans, and they're not even hitting 60fps at 4K.
What you should see in that review is quite obvious. There are games at 4K where the bottleneck can easily be the card. Metro, for example is more demanding than any of the games you listed. Which is why I said "depends on the game"
Yes, his CPU will hold him back in many cases, but at 4K there will be several games where a 980Ti is getting all it can handle.
you will be fine then, those games will hardly mean any GPU/CPU intensive problem for your setup..
Eh, who the heck runs their CPU at stock anway? Most 3570K hits 4.4hz on stock voltage. Plus, Windows 10 will solve the CPU bandwidth issue. I wouldn't upgrade the CPU yet until Windows 10 come out with benchmarks.
And still be a massive upgrade compared to his current card. Silly for a CPU upgrade now when Skylake will be here in September
Uh, something seems off there... it shows a 4770k consistently beating a 4930k. That makes zero sense.what should I see in that review?.. I can show you one dedicated to 4K gaming.. where a i7 4930K perform slower than a i7 4770K being yes, a bottleneck.. what do you think a tiny old i5 750 can do to a 980TI?.. Review I know exactly how that CPU perform and also know the demands of 4K...
some images:
<snip>
Wrong, the 4770k and the 4930k both have exactly the same Turbo frequency, 3.9 GHzhaswell have some features that make it better than ivy bridge.. but also add the clock advantage the 4770K boost up to 3.8ghz while the 4930K boost up to 3.6ghz, that little difference can be enough
Uh, you realize this isn't Haswell vs. Ivy Bridge, right? This is Haswell vs. Ivy Bridge-E......the sequential and vectoring processing its about 10% faster in haswell vs ivy bridge.. which again also play a good role at high resolutions.. adding the average 10% IPC increased...
Actually, you wont get the max out of your 980 TI, so upgrade your cpu/system or get a lower end card, unless you think the 980 TI is sexy as helland you want one no matter what
Ill post this again. My 920 @ 4k was a huge bottleneck. Upgrading CPU gave me a higher frame rate in 90 percent of my games.
The 4930k has more L2 cache (2MB vs 1MB)
The 4930k has more L3 cache (12MB vs 8MB)
The 4930k has more cores (6 vs 4)
The 4930k has more threads (12 vs 8)
The 4930k has more memory bandwidth (60,000 MB/s vs. 25,600 MB/s)
The 4930k has a better Passmark (Multi-core) score (13,000 vs 10,000)
The 4930k has more PCIe 3.0 lanes (40 vs 16)
The 4770k has a better Passmark (Single-core) score (2165 vs 2000 ... an 8% difference)
By almost every measure, the 4930k blows the 4770k out of the water. It has every advantage (including full native 16x/16x SLI bandwidth), there's NO reason it should be performing so much worse than a 4770k in those benchmarks.
Why would he not get max performance out of the GPU? What CPU is needed to get max perf with a 980 Ti?
