GTX 970 on 4K
asheron42
A while ago I started using a 4k tv and I'm getting random artifacting. It can happen during gaming or while browsing the web. The issue is a horizontal bar in the upper part of the screen that blinks on for a second and then goes away. It happens a few times a day and is accompanied by a buzzing like sound from the speakers. I'm using onboard analog audio outputs instead of hdmi outputs. I've tried various combinations of drivers. If I switch to only hdmi, I haven't observed the behavior; but this isn't compatible with my sound system. I've tried to setup with the motherboard drivers and directly with the chipset drivers, both have the same issue. If I go with a 1440p monitor, I also don't seem to have the issue.
Has anyone run across this issue?
Maybe some sort of interference.
I know I was getting buzzing sounds due to the analog audio on my motherboard, and I had to get a USB audio adapter to fix it.
This is the one I use, for $10: https://www.amazon.com/gp/product/B01N905VOY/
There are more expensive ones if you need 5.1/7.1 audio. Probably worth trying.
I would try a different HDMI cable and/or audio cables, some cables are prone to interference
^^this^^
I had issues with my 970 SLi pair at 4K and it was a combination of needing a firmware update on my cards (to support hdmi 2.0 properly) and a bettter 18gbps hdmi cable.
