vividshock
- May 31, 2014
Arriving tomorrow is my GTX 780 HOF and I was thinking I'd swap out the stock cooler and use my H90 on it. I'm planning on clocking this baby to the moon. So far I took a quick glance @ the reference and HOF PCB (List of GTX 780s) and it looks like I might be able to do the swap. The only thing that's stopping me from doing this from the start is the thought that the H90 wouldn't dissipate fast enough when compared to the stock cooler.
Also if I'm planning to overvolt to 1.25 ~ 1.3 or if I'm able to go higher....what temperature should the core be? My understanding is that if you overvolt the core you're going to need temperatures way below the 80c threshold to prevent throttling, but I feel there's also another reason for it also.
