Hi guys, its been eons since I've last gamed and I'm upgrading from a 4850, E6700 intel core 2 duo. Yes its been that long!
Being a skint student my desires have fueled me to make a rather excessive purchase to play Skyrim and BF3.
i5 2500k processor with 8GB of memory is on its way due to an early xmas present and I am looking at a GTX 570 to play on my 1680x1050 screen. HOWEVER I'm running on a OCZ 520w PSU. I know the PSU is under the recommended limit but imo they overrate the recommended settings slightly and Guru3d seems to think the overall rate of power is lower than that of 520W.
http://www.ocztechnology.com/ocz-modstream-power-supply-eol.html is the PSU I have, I am unfamiliar with Rails and Amps and I'm pretty concerned about if this PSU will cope with the new rig, in particular the GTX570 I consider purchesing.
95~132Vac /190~264Vac 10/6a
200~240Vac Only**
520W: +3.3V(28A), +5V(52A), +12V(28A)
is the Spec (check link for more)
Any help would be appreciated as I'm lacking the knowhow these days.
200~240Vac Only**
