GTX 570 Power Supply
JunkieJZ
My specs are:
i7 920: Stock Voltage @ 3.6
Asus P6T Mobo
6gb of Ram at about 1600
4 WD Harddrives
2 DVD RW Drives
4 fans
Sound Blaster Fatality Sound Card
About 8 USB Devices
My current Power Supply is a Corsair HX850. I have no desire to go SLI with this rig. I presume that I should be good with my current power supply, but I'd like to make sure.
Thanks for the feedback, as always.
I have a 430W power supply on a similar system. So yes your 850 is plenty..
Not even a question...you would have enough power for tri-sli most likely.
