My system consists of
XFX XXX 650w PSU
Asus m4a89gtd pro USB 3.0
Phenom 1055t @ 4ghz @ 1.4v
Asus GTX-470
8gb DDR3 1600mhz (4 sticks)
3x Seagate 7200.12 1tb drives in Raid
Corsair H50 cooler
XSPC waterloop for gpu
7 120mm fans
2 80mm fans
6 usb devices
Whenever I oc my video card it will run occt for like 2 min then the screen will go blank and then i have to hard start the pc a few times for it to post again. I thought this was a voltage problem, but I can raise the voltage all the way to 1.087 on the gpu and leave the clocks at stock and it won't cause any problems....but if i raise the voltage and up the card to 800/1600/default mem it will cause that problem and screen will go black. It will do it in both the occt-gpu test and the power supply test. Any ideas?
XFX XXX 650w PSU
Asus GTX-470
Corsair H50 cooler
7 120mm fans
2 80mm fans
6 usb devices
