GTX 460 question
botw
How much of an upgrade would a GTX 460 768mb be over a 512mb 4850?
Prices on these have come way down and I am thinking about picking one up. Any better options in the $125 price range?
40% maybe?
4850 is about 30% slower than GTX 260... GTX 460 768 is probably 10-15% faster GTX 260.
40% maybe?
More, but overclocking is a factor. The 4850 and 4870 (which was my previous card) had very poor overclocking. The 4870 could go to 800 over its default 750 for a longtime stable OC, whereas the 460 can do 800 (with a healthy margin to spare) over its 675 default.
overclocking is not a factor because overclocking is BIG YMMV> You do realize 4850 also overclocks.
If we started to account for overclocking performance there's no end to what clocks can be generated to compare to what card.
For the upper limits yes, but there are averages that tell the story.
You can check a dozen review sites, that do test for overclocking, and get an idea of what to expect. Usually you want to take their results and discount a bit.
In fact, the pre-OCed models tell the story too. Find the 5 best pre-OCed models of any said card, and that will give you a pretty good idea of what you can expect.
+1
It's all in the OC'n with the 460s
I will agree with the above too. I had two 4850's and neither overclocked well at all. My gtx 460's overclock to faster than 470 speeds. Personally I think it is a huge upgrade.
I don't have my 4850 OC'd because I am cooling it passively and they are already pretty hot cards.
BTW - resolution is 1600x1200. Main rig in signature.
would you overclock the 460?? it wouldn't be passive
Maybe, but not much. I want to balance performance, noise and heat as much as possible.
Again overclocking is YMMV... as it's different from each card. 1 guy could be hitting 1000 and another guy barely break stock... It's silly to compare overclocked performance vs a stock card.
Now we should be comparing pre-overclocked cards vs factory cards? :eek:
I've seen 4850 topple near 4870 speeds so why don't you account for that? Oh right you only compare stock vs future overclocked cards. :rolleyes:
I got exactly three degrees difference when overclocking from the default speed to 800/1900, which is what I game at. Four if I push it to its stable limit - 840/2000. It uses a reference cooling design BTW. Note that some sites explicitly say they have never encountered a GTX460 that couldn't OC to 800 comfortably.
Alright well if you don't want him to get a 460 and OC it....
there's that 4870x2 for $125! a DAMN good upgrade for him, and he never needs to touch a slider
