GTX 460 Keeps EUEing
osrk
Any thoughts? Using the latest drivers and it will EUE out after 4 or 5 work units. Temperatures do not go above 75 C. Windows 7 and no overclocking. I tried to increase the voltage a tiny bit but to no effect. Is the card just tired of folding?
Yea keep an eye on the units my GTX 460 would do that often with a particular unit that had issues. If it is a couple different units try dialing back the OC some or bump up the voltage if you can.
