I thought it was the 5830...
From what I can tell according to benchmarks the 460 is comparable to the 5850 when it comes to performance numbers. If this is the case how in the hell is the 5850 priced so much higher???
Since when is a 460 $100 cheaper than a 5850? If you are comparing the cheapest 768 memory 460 to the most expensive 1GB 5850 then you are a fool....the amount of extra performance that you get for the $60-100 extra dollars on the 5850 makes the 460 much more desirable, imo.
460 is a great card, and will drive the price down on the 5850. I've already seen an xfx without a MIR for $250. Let it begin..
when ATI and Nvidia's refresh comes near the end of the year i think the competition will get much more interesting..
Yeah, but XFX is using a shitty non-reference PCB and HSF design that is far cheaper in cost and inferior in function to the more expensive reference cards.
The non-reference PCB and HSF designs are common among AIBs, not just an XFX thing. I don't agree that it is neccessarily "shitty" but if it were me, I would agree that purchasing a reference design is a good idea.
The ATI 460 GTX is the 5830.
Which is NOW priced under the 460 (which is should be).
You can pick them up for $180 bucks now.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161327&cm_re=5830-_-14-161-327-_-Product
They now need to get the 5850 around $230-250 range.
no they dont.. sure we want them to drop it to 230-250 but they dont need to..
They do need too, You do realize they were suppose to be $259 in the first place?.... Most of the 460 1gigs arent stock and come overclocked for around $240 which keeps it on the brink of the 5850 in benchmarks.
And with the way the 460 Scale with Multi-GPU configuration, The 460 is a no brainer.
Look at these benches....It so damn close to the 5850, and its around 30-50 bucks cheaper.
http://www.guru3d.com/article/kfa2-geforce-gtx-460-1024mb-gc-soc-review/
It is time to lower them
so damn close yet so far away when you overclock a 5850.. darn guess that 30-50 dollars you saved didnt go so far now did it.. i wont argue that sli scales much better then crossfire.. but thats still another 200+ dollars your spending to get better performance then a single 5850.. at that point ya might as well just get a 5870.. and yeah you dont need a second card to run multi-display either..
2 gtx 460 beats the 5870 and gtx 480 for about the same or lower price.
The 5850 may be faster overall, but it's not like you can't OC the 460 just as well to close the gap again. As for bang/buck...I'm inclined to believe HardOCP's numbers.
Sigh. You do know that overclocking goes both ways, eh?
It's getting pretty annoying reading about all these OC'd 460 comparisons to a stock 5850.
Getting 2 cards to beat the performance of a single higher up card is rarely if ever a good idea or investment. Not all games work well with SLI or Crossfire, so when you have to use a single card there goes your performance increase. Also, you could argue two cards is harder on the PSU, which can be bad if you have a shitty one.
I'd definitely be interested in seeing some overclocked 5850 vs overclocked 460 benchmarks. The 460 seems to be a great overclocker, with cards being released at 800and 810MHz out of the factory (Gainward GLH and Galaxy super OC). That's 20% straight out of the factory.
To me it says a bit when manufacturers are happy to release models at a 20% overclock... but of course I'd like to see benchmarks before I make any judgements on it![]()
Call of Duty: World at War
1680 x 1050, 4xAA, 16xAF, DX9, Maximum Detail, Recorded demo
5850 = 127 fps average
5850 850mhz = 145 fps average (14% gain over stock)
5850 1Ghz = 156 fps average (22% gain over stock)
4850 X2 = 137 fps average
1920 x 1080, 4xAA, 16xAF, DX9, Maximum Detail, Recorded demo
5850 = 117 fps average
5850 850mhz = 132 fps average (12% gain over stock)
5850 1Ghz = 148 fps average (26% gain over stock)
4850 X2 = 128 fps average
Call of Juarez:
1680 x 1050, 4xAA, DX10, Highest Quality Settings
5850 = 63 fps average
5850 850mhz = 73 fps average (15% gain over stock)
5850 1Ghz = 79 fps average (25% gain over stock)
4850 X2 = 62 fps average
Crysis:
1600 x 1200, DX10, 64 bit, Very High, 0xAA
5850 = 34 fps average
5850 850mhz = 37 fps average (8% gain over stock)
5850 1Ghz = 44 fps average (29% gain over stock)
4850 X2 = 35 fps average
Crysis:
1900 x 1200, DX10, 64 bit, Very High, 0xAA
5850 = 30 fps average
5850 850mhz = 34 fps average (13% gain over stock)
5850 1Ghz = 37 fps average (23% gain over stock)
4850 X2 = 30 fps average
Crysis:
1920 x 1080, DX10, 64 bit, Very High, 4xAA
5850 = 27 fps average
5850 850mhz = 31 fps average (14% gain over stock)
5850 1Ghz = 34 fps average (25% gain over stock)
4850 X2 = 27 fps average
Devil May Cry 4:
1600 x 1200, DX10, 8xAA, 16xAF, Highest Quality Settings
5850 = 141 fps average
5850 1Ghz = 176 fps average (24% gain over stock)
4850 X2 = 157 fps average
Dirt 2:
1920 x 1080, DX11, 8xAA, Ultra Quality Settings
5850 = 47 fps average
5850 1Ghz = 58 fps average (23% gain over stock)
4850 X2 = N/A
Resident Evil 5:
1680 x 1050, DX10, 16xAF, 8xAA, Highest Quality Settings, Motion Blur Enabled
5850 = 83 fps average
5850 1Ghz = 100 fps average (20% gain over stock)
4850 X2 = 87 fps average
A GTX 460 1GB is only $30 cheaper than a HD 5850 1GB and the 5850 can be overclocked easily to 5870 clocks which crushes both the overclocked 768MB and 1GB GTX460 performance. There is simply no comparison. The best value has always been the 5850.
all that taken into consideration i would rather have a 5850 because it is faster, however i cannot justify the extra $50 when i consider that i also have to upgrade my psu. if we are talking about value then there really is no comparison: the 460 wins hands down.
i have to upgrade my psu regardless. since you have absolutely no idea of what kind of system i am running i advise you to take your own advice and quit the bullshit. you clearly did not understand my post so i will spell it out for you: i cannot justify spending an extra $50 on a video card because I HAVE TO BUY A NEW PSU REGARDLESS OF WHAT CARD I BUY and my budget is already stretched. there.
Because performance of one maker's video cards has little influence on the other maker's prices.If this is the case how in the hell is the 5850 priced so much higher???
