gtx 295 vs. gtx 285 size difference?
mike87
i'm looking to upgrade from a gtx 285 to gtx 295 (for only $300 too). if i can fit a gtx 285 comfortably in my lian li 6070B case, would a gtx 295 single PCB fit fine?
From the time I had the 280 and 295 side by side they were pretty much identical (dual PCB is mine btw)
Hopefully someone else has a more accurate experience but it should be pretty much the same I think.
yeah i've read online that both are around 10.5", but i just wanted to double check on here
