GTX 295 all the same?
rennocneb
Are all the GTX 295's the same? are they all refrence designs cause ive tried my second BFG and both Squeal terribly.
Im debating going to a phenom II instead of a Core i7 so i can swing GTX 285 SLI vs a GTX 295 with the core i7 which should give me a better gaming experience?
I'd buy the Core i7. Video cards come and go. Later on when DX11 comes out you'll be wanting another one. I would also consider buying the Core i7 with just one GTX 285.
imo, the gtx295 seemed to be a desperate attempt by nvidia to gain the performance crown. Sandwiching two card together like that just seemed lazy and is a poor design choice. Heat would be horrible. I would go with i7, it would last you longer than this card would.
Yea i have a 295 now had it about 3 days but the thing is going back it idles in the mid 60;s loads about 95C its loud, and under load the power circuits sound like they are about to launch into orbit. Does anyone know if the 285's suffer a similar fate as far as the squealing goes? I guess most of the 295's do it from what ive read.
