Hi all-
I just built a system and seem to be having resolution issues after updating some drivers.
Long story short, when I first loaded VISTA Home Prem. 64 the resolution was full screen at 1280 x 1024 (or whatever the default is before you load drivers for the video card or MB. After updating the ASUS P6T Drivers, the resolution on the TV (40") will not go higher then 1280 x 1024 and there are about 8 inches on both sides of the screen where there are black spaces. Adjusting the settings on the TV will work if I go to the FULL stetting but the desktop cuts the tool bar on the bottom off and and some of the screen on the other sides. When I go to adjust settings for resolution, there are no options for adjusting resolution on the GTX 285 its self. As if the drivers for the video card are not working. The video card shows up in the device manager section with no issues.
Just wo ndering if anyone else had the issue or has a solution. Thank you for your time.
