ChthonicDepths
- May 7, 2009
What is considered "safe" for 280 VRM temps?
I ask, due to the fact that Thermalright never fixed the problem they claimed they were fixing with their aftermarket cooler for the 280, and the plate with thermal pads does a miserable job at cooling the VRMs, which they knew was over-heating GPUs.
They pulled it originally and pushed back the release date last year, then re-released it, and it's still garbage. I checked around, and apparently I'm not the only having this problem, so it obviously was not resolved by Thermalright.
The sink does excellent at keeping the core cool, but as for the VRMs, they're hitting temps upwards of 80C+ when under heavy load from something such as Crysis, and even upwards of 70C with TF2. The friggin' stock cooler (which I no longer have, unfortunately) did a far better job.
Will the VRM's just simply fry at some point at those temps?
Any other coolers out there worth it to replace this junk? I've been checking, but I'm not really seeing anything for the 280 right now.
Thanks.
Thanks.
