how many power connectors does the GTX 280 need? I have 4 6pin connectors and 1 8pin which I use for my motherboard. I heard somewhere that the GTX 280 needs 1 6 pin and 1 8pin?
I jumped on that deal also, and I have the Corsair 450watt. The Corsair PSU Finder says im good for both GTX 260 and 280. I only run Q6600 with 4GB ram and 1 hard drive though.
edit: linky I even asked the PSU forum about it.
Probably not. Your current PSU should be able to handle it.I may have to upgrade then.
The HX520 can handle a GTX280 no problem, even with a quad. With a dual-core, it obviously can as well.I'm in the same boat with a Corsair 520W, but I only have a C2D. From what I've been reading there are people who are running quad cores with the GTX 280 on this PS. It sounds like the Corsair should be able to handle it, unless you have a ton of extra drives and things running in your case or if you're doing extreme overclocking of both CPU and video card. I only have 2 drives, a DVD and no other PCI cards, so I figure I should be okay if others are running this card with quad cores.
