I just got a GTX 275, upgrading from an 8800GT, I uninstalled the old drivers first, etc..
Well when I install the new drivers (ones from CD or new from nvidia.com, didn't check if they're the same) I end up with Windows booting with about 1/3 of the screen cut off on the right side, an odd resolution, and hard to read text (probably due to the resolution haha). Basically Windows isn't centered, and I can't see the start icon or about a 1/3 of that side.
Does anyone have an idea what might be going on? It works fine if I take the drivers off, but I can't do much without them.
Thanks
Thanks
