for sli lets say i have this gtx 260 core 216
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150329
and then decide to get the XFX GX260NADBF GeForce GTX 260 Black Edition that is clocked higher
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150330
would I have any problems since one is black editon OC higher and the other one is not, regular core 216 when Sli'd?
If you have the sli mobo(which you do), I would go with the 260s because you can get two 260s for the same price as one 285, and two 260s is a lot better than a single 285, and is on par with the 295. You do have to take into consideration case size and the extra heat with the two 260s though.
I really like to know what Nvidia is thinking by pricing 285s so high now that 275 and HD 4890 are out. GTX 285 vanilla should be down to $300 (at least) for it to make sense price wise.
