GTX 1080 on NiceHAsh
Discussion in 'Mining & Cryptocurrency' started by RICCO75, Jun 18, 2018.
  1. RICCO75
    RICCO75 n00bie
    4
    Jun 11, 2018
    Hello Guys
    I would like to make some minng test with a friend computer : Dell AlienWare
    This computer have got Inside a GTX 1080.
    I make no change on his computer : all drivers are up to date. (no particuliary overclock)
    I'am connected on Nicehash and work on Lyra2Z
    If i go to
    http://whattomine.com/
    and select GPU 1080 on Lyra2REV2 hash is :46500.00 Kh/s
    On the Nicehash website my speed is : 2Mh/S
    Is a bad speed ?
    Why so big difference beetwen : http://whattomine.com/ and https://www.nicehash.com/
    Thanks
  2. serial__thrilla
    serial__thrilla [H]Lite
    101
    Jan 5, 2018
    Websites usually take a while to update and catch up to your actual speed, so that could be why. Did you look at what the Nicehash client reports? Like the actual desktop client?
  3. Parja
    Parja [H]ardForum Junkie
    12,676
    Oct 4, 2002
    You're talking about two different algorithms.
    Lyra2Z and Lyra2REv2 are two completely different algorithms. 2 Mh/s on Lyra2Z sounds roughly right for a stock clock 1080. Lyra2REv2 would probably result in something in the low-40s Mh/s.
  4. serial__thrilla
    101
    Jan 5, 2018
    Ahh good catch. I'm an AMD guy myself, so didn't pick up on this difference.
