GTW 250 $65AR + FS (possible)
Rydawg5143
Product
Rebate
Now while it all seems good and well. When you go to submit your rebate you can see the code isnt valid but there is another rebate for the product with a different serial number, one of which is only one of the newegg one. My thoughts are someone on the worlwiderebates side screwed up while inputting the serial #. I'm going to order and hope for the best!
If you search for the newegg part name the newegg rebates, the rebate is on Neweggs site - it's just not on the product page itself.
I ordered one.
I have noticed sometimes Newegg drops the prices and removes the rebate even if its still valid. They did that on an OCZ ram deal a while back.
They have the rebate in rebate center, but remove it from the item. I guess wosrt case you still get a gts 250 for $105 which is still a great price. and if things go right you get a killer deal and get the card for $65 or whatever which would be the deal of the year/ or at least best card for $65
Nice deal, but not a worthy upgrade from my trusty 8800GT and I don't have an SLI board or capable PSU.
Either way, grabbing 2 of these would be a whole lot of power for a mere $130.
Looks like it's back in stock, I think I might order one... the part number checks out and all the rebate information (It's vaild until June 30th!) at $105, I think it should be $145 - $40 rebate, but oh well :D
Wish I could make use of it for 1 build, but 2 x PCI-E power makes it a no go...
But this is a $130 card for $65 :D Whether it's to keep for another build or resell, it's a great deal.
And I've had good luck with this rebate company, I've picked "no-wait" service (They take a small percentage out, they were two $15 rebates, and I got checks for $13) but it took like 3-4 weeks at most.
EDIT: Or not... it seems it just went back out of stock (Or was it never back instock? I saw the "Add to Cart" option, then went to click it after typing this post and now it's Auto-notify") >_<
I put this on autonotify. as one of the above posters states the rebate is good so long as it's purchased before June 30th also worth noting is that it isn't limit one rebate per address it's limit 2. They want you to buy 2 and SLI them..:eek:.. I'll order 1 as soon as they come back in stock.:D.....If they come back in stock:confused: Why didn't i buy a board that supported SLI.... hmmm still a good deal for $65.
Sadly no.
Happily yes. A quick search yielded the answer.
Nvidia says the GTS 250 will willingly participate in an SLI pairing alongside a GeForce 9800 GTX+ of the same memory size. Unfortunately, though, 512MB and 1GB cards will not match, and Nvidia's drivers won't treat a 1GB card as if it were a 512MB card for the sake of multi-GPU cross-compatibility, like AMD's will.
Another quick search should yield also reveals that many difference brands use different versions of the GPU chip for the 9800GTX +, so make sure if yours is the 65nm version and if the one you are buying is 65nm, or 55nm vice versa.
Bump... it's back in stock for $5 more but free shipping...
Ordered 2... Model numbers + dates check out, rebate is good for 2 cards...
$70 each :D
Well the rebate is listed as that part number, newegg is place of purchase, and purchase date is until end of June.
You can check the code on the rebate site and it works as well.
Part number matches on Newegg as well...
So everything add's up... maybe Galaxy didn't intend for the rebate to go that long or maybe for their card to be priced as low so they told Newegg to remove the rebate? I dunno...
Supposedly the reason the price is so low is because they changed their minds and had Newegg apply an instant rebate instead of a mail in one but the form's already been made.
Yea, that makes sense... basically they're trying to hide the fact that the rebate exists... but they should have just waited till the rebate expired then made it an instant rebate :eek:
They still have to honor it though, I'll punch them in the ovaries if they don't -_-
Pretty awesome deal... in for two so we'll see how the rebate goes.
Dad is gonna love his new computer :)
Maybe Galaxy is in financial trouble and trying to liquidate, like that huge stash Dell just dumped. Declare bankruptcy in a month and save a million on floating rebates after cashing in for investors :)
2 years ago I got a Galaxy 3870 and the rebate came in nice and fast though. Card still works perfectly as well.
If the rebate comes in it is gravy. Seems like this model is coming down in price a nice amount.
I bit. That's 4 video cards in the last 2 weeks that I bought because they were so cheap but didn't need. :(
If you read the Newegg reviews it isn't a real GTS 250, rather a mislabeled 9800GTX+. There are two power connectors where there should only be one.
There are other GTS250's like this as well... the GTS250 is basically a 9800GTX+ ... it's still a good price :p
