GTA:SA no sound certain scenes
i dunno why but half the cutscenes have sound and others don't(like the ones when i start a mission do but none of the others) and cell phone makes no sound and i cant here people talking to me when its not a cutscene wtf gives?
like in the cutscene after you beat the crack dealer down....no sound just mouths moving...any way to fix this?
and then here the guys moving his mouth and making hand expression but i cant hear him
come on guys help me or something.....i think it has something to do with it sending out audio on a center channel instead of stereo which is what my headphones are.....i have the windows thing set to headphones but i dunno what else to do
ive had this issue in other games
You need to change your speaker settings. If your sound settings in control panel is set to 5.1 and such, you need to set it to 4 or 2 speakers for GTA:SA.
I had this problem and I fixed it by using an older version of eax.dll. You can find the version I used with this link. I got it from here, which might help if this doesn't fix it.
Thanks, ill have to try it when i get on my other pc....then i'll have to finally beat one of the damn mission to see if it works....im stuck on all of em
no it doesnt work....i installed it into the windows/system directory like it said.........
also tried the game directory....no go
