GTA IV - ENB Series (SORA)
Shantarr.Dalrae
I am having a beast of a time getting this to work. Any tips or tricks?
Also the host site for the files appears to be down, whassup with that?
Thank you!
Works fine for me. 1680x1050 eith 2x2 Supersampling AA. Very heavy hit on performance, though.
Do you have the just released patch installed? That is not compatible with the ENB series mod
Ah, so I assume I need to re-install the game from scratch and disable GFWL then manually patch to just before the most recent and run it?
Edit: Also, thank you for your response!
