GT630 with 3 monitors....works???
/dev/null
Work recently bought an Nvidia GT630 with 2 displayport & 1 DVI. I realized after it was bought it wouldn't support 3 monitors, however I gave it a shot anyhow. Apparently twinview sees all 3 monitors & lets me enable them.
Anyone know if other GT630s work with 3 monitors?
Here is info from linux:
rob@desktop:~$ lspci -s 05:00.0 -n
05:00.0 0300: 10de:0fc2 (rev a1)
05:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GT 630 OEM] (rev a1)
rob@desktop:~$ xrandr
Screen 0: minimum 8 x 8, current 5760 x 1200, maximum 16384 x 16384
DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
DVI-I-1 connected 1920x1200+3840+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 60.0*+
1920x1080 60.0
1680x1050 60.0
1600x1200 60.0
1440x900 59.9
1280x1024 60.0
1280x960 60.0
1024x768 60.0
800x600 60.3
640x480 59.9
DP-0 connected 1920x1200+1920+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 60.0*+
1920x1080 60.0
1680x1050 60.0
1600x1200 60.0
1440x900 59.9
1280x1024 60.0
1280x960 60.0
1024x768 60.0
800x600 60.3
640x480 59.9
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 connected 1920x1200+0+0 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 60.0*+
1920x1080 60.0
1680x1050 60.0
1600x1200 60.0
1440x900 59.9
1280x1024 60.0
1280x960 60.0
1024x768 60.0
800x600 60.3
640x480 59.9
Here is the card I purchased:
http://www.cdw.com/shop/products/NVIDIA-GeForce-GT630-DP-graphics-card-GF-GT-630-2-GB/2754956.aspx
All Keplers support up to four monitors. I would just stay away from the cards that have D-Sub ports.
I was under the impression that GT630's were rebranded GT440's...? My nvidia info says this has 192 cuda cores & 128-bit bus as well.
According to Nvidia, my card doesn't fit the kepler GT630, since that has 384 cuda cores. Actually none of the GT630s there has 192 cuda cores. Is that weird or what?
Edit: Hmm, maybe I have the OEM one...? However my card has 2 displayport & 1 DVI and I don't see a mention of displayport anywhere in the 630 or OEM specs...
Edit 2: HP says it's a kepler and a "GTX 630"
http://h30094.www3.hp.com/product/sku/10430126
I am running 2 DVI + 1 HDMI->DVI with a 640. I don't know how related a 640 is to a 630. (Linux programming, if you're wondering.)
I think 640+ is SUPPOSED to support 3+. From all my googling, 630 & less don't support more than 2 (except maybe for this weird card...?)
