What is the difference between a Nvidia GTS, and a GSO card? It's my understanding that LE<vanilla<GT<GTS<Ultra . Where does the GSO fall?
LE/XT<Vanilla<GSO/GS<GTS<GT<Ultra
Fixed.
LE/XT<Vanilla<GSO/GS<GTS<GT<GTX<Ultra
Fixed.
are you really saying a 8800gts is worse than an 8800gt?
Fixed.
LE/XT < Vanilla < GS/GSO < GT < GTS < GTX < Ultra < GX2/dual gpu cards
This can be followed quite accurately with the exception of the 8800 series, just like how ati's 4770 is faster than the 4830 for example.
ATI used to have these:
PRO (NVIDIA XT/LE equivalent)
XT (NVIDIA GT/GTS equivalent)
XTX (NVIDIA GTX/Ultra equivalent)
Well if XT/LE are really below vanilla, wouldn't it be more equivalent to ATI's SE suffix. I am pretty sure the 9600 SE was cheaper and worse than the 9600. I mean, ATI did have vanilla cards, such as a 9600. The 9600 Pro was better and really popular IIRC. Otherwise I would say comparison of the ATI to Nvidia suffixes are correct. I gotta say, I like the new naming schema ATI uses better than all these suffix crap. The higher the number, the better it is, as long as your in the same series, such as 4xxx or 5xxx.
