honegod
- Aug 31, 2000
Ripjaws V 2x8 2400.
Stamped aluminium with sticky thermal tape.
Each stick has one side populated, the other empty.
The tape sticks to the memory bits well, and peels off with reasonable prying.
The tape sticks to the circuit board astonishingly well and unsticking them is not a trivial exercise.
The tape stays on the aluminium.
The contact points are clearly marked on the tape.
Less than half of the memory area had made contact with the tape.
The aluminium has a big 'V' stamped into it, which lifts most of the available tape area out of reach of the memory.
Which introduces an air layer to insulate the memory it touches.
So in its stock configuration half of the memory is insulated from the heatspreader and may be expected to get hotter than if the tape made actual contact.
And it is intended to run that way.
Ripjaws V 2x16 3600.
Same stamped aluminium bits, same thermal tape.
The stick has memory on both sides.
So it was easy to pull both sides apart.
8 per side,a cluster of 4 at each end.
Only the outermost unit on each end made complete contact.
The tape ends halfway down the rectangle contact patch.
the next one in from the ends is right under the stamped edge and they were cut off randomly.
The middle 8 (both sides) Made no contact at all.
The stamped V is cut away on the sides and bottom to insure that any heat that might be transferred to the aluminium cannot get to the aluminium in the middle of the V.
I really like the thermal tape.
If I found out how to get some I'd definitely tape nice flat strips of 2mm Chinese copper.
Even though just peeling the aluminium off should lower temperatures from stock.
