Michael Daly
- Jan 6, 2007
I added a front panel gadget to provide audio connections to the front of my case. This means attaching a 2x5 connector to the audio header on my Gigabyte DQ6 MB. It turns out that they placed some capacitors so close to the header that I had to shave down the plastic on one side of the connector to get it to fit.
I wish they'd test these things with the kind of products that we can actually use in the real world. I find it hard to believe that the only 2x5 connectors they can find to test with happen to be the slimmest in the world.
