Monkey34
- Apr 11, 2003
Running WinXP pro here btw.
I wasn't happy with the default set-up of my childrens computer (it has a login for myself, and each of my kids)..seeing as it created them all as administrators. I am inherently cautious where my kids are concerned, so I run software to restrict thier internet usage by shutting the internet off at 10pm (I dont want to find my son on-line at 2am surfing). Well, the bugger just changed the system time to get around that one.
I ended up making them all power users, and only allowing administrators permission to change the system time.
The only problem with that is occationally, one of them wont be able to install a game or driver, or another odd issue will rear its head. Can I "copy" the administator group, rename it(putting the kids into it, and then resticting the "change system time" from them), or am I stuck adding permissions for issues as they pop up?
Basically, should I start with full - removing permissions as needed, or start restricted and add as I go?
