How necessary is this, especially for overclocking? I'm painting the inside of my case, and it's got the kind of mobo tray that if you remove the side panel on the mobo side of the case and remove a few screws securing the tray, the tray 'tips' down to expose the mobo. The tray is hinged at the bottom of the case.
I got to wondering- since the tray isn't permanently fastened to the case- and what few points of contact there are will probably have paint on them - would I perhaps need a ground strap running to the tray from either the PSU case or at least the PC case? Or will the grounding thru the PSU cables be enough?
