Borgschulze
- Feb 28, 2005
So I am decided on cutting some holes in my case for tubing...
This is how my case is now.
And this is how I am going to do it.
The radiator will be mounted an inch or two off of the case, and just the tubing will have holes, I don't want the warm air rising through my radiator.
Now.. I can't find any places locally that sell Gromets that are 1/2" ID, only 1/2" OD... which are quite small ID. Anyone know of a local place in Hamilton that sells 1/2" ID Gromets?
And also... I want some advice on drilling holes for the tubing. I have a 3/4" Holesaw (Smallest one in the kit).
Also, what do you people think about my change of plan?
How do you like my T-Line, it was only $2 and it's made out of copper pipe
