I'm going to be painting the outer panels of an old case, but I need help figuring out what sandpaper grit to use for sanding before painting.
The panels are aluminum and the front is plastic. I was thinking i'd use like 50-60(?) grit before the first coat, and then a finer grit like 240(?) between coats. Is that ok?
Also, do I sand one last time before putting a clear coat?
