Green Artifacts In Videos
hawkeh
Alright I have a XFX 6800 xt video card that I've been using for about 1.5 years now. Never had a problem with it till yesterday, for some reason green artifacts (like a huge green grid that flickers and covers the whole video window) show up. Also when playing games like CSS the same type of thing happens to the point where its completely unplayable.
I tried taking a screenshot but for some reason its not picking up the artifacts :confused: . I also tried removing all my drivers and reinstalling them (tried 2 separate drivers). The temps are normal and the fan is working fine, even vacuumed the dust out...
Is my card about to die? This only happens when I'm playing games and movies.
I have a 6800 and I'm having the same problems. My monitor is brand new it's got to be the gfx card.
i had the same problem a while ago with my friends machine. its the GFX card.
Weird thing is I can play videos on YouTube fine without problems but as soon as I try in VLC/ WMP I get the artifacts.
Don't think it's your monitor... you'd have the same graphical glitch in different situations.
If you're getting a color shift I really suspect it might be something to do with the way the card is being connected to the monitor. Are one of the pins bent and/or broken? Maybe the video port on the video card is toast. Can you connect your monitor in a different way? Like use DVI instead of VGA. These are just ideas.
I managed to get a screenshot showing what it looks like CSS (although it looks a lot worse than in the screenshot)
