great tool for wireless laptops
LBJuice
Mobile Net Switch. I searched for an app. like this for a while now, and finally came across this figured I'd share it. I'm bad at describing things so
Do you connect to more than one network? Don't want to reconfigure your computer for every new location??
The powerful easy to use interface allows you to configure your computer for every network you will be connecting to (Workgroup or Domain). It's the perfect solution for everyone with a mobile computer who is using it on more than one network (e.g. when you are using your machine on multiple locations, offices or at home).
Each location is stored in a profile. Simply select a profile and your drives will be mapped correctly, the correct default printer will be selected, IP Addresses will be set correctly, the correct Proxy Server will be configured, and much more. You will be able to use your machine on any network with ease!
http://www.mobilenetswitch.com/Download/
Is this thing spyware/adware free?
Looks awfully pro to be a simple free utility. Something has to be paying for it.
-Larry
does windows XP already list diff networks and let you choose which to connect to :(secured or not, with in range et cetera?)
at least it does for me.....
yeah but it isnt smart enough to now "oh im on this network now...lets map these drives after we un map the existing ones"
This would be useful for the teachers at my work, at the moment we setup firefox to work with our proxy and tell them to use IE at home ... dont think we can justify the cost tho :)
