So if they cant sell ipod knock-offs then the 4gig versions r gone also Y or N? I havnt been able to find a link.
Ya this realy sucks. They are all gone.. Wonder why they took or were forced to take them down?
Does anyone have an real good pictures of the Glacier?
I thought I had seen some somewhere, but lost the link. I would also like some pix of those metallic looking ones if anyone has any.
Its true. But quality is.....suckiest sucker that ever sucked. Dont even think of buying this camera.Has anyone tried the digital cameras? The only one I actually care about is the one that claims to be 12 MP. For $130 thats not bad but if its sounds too good to be true.....
Anyone buy the 4gb ipod knockoff from ebay? It doesn't say "Full Metal Platinum" but looks almost identical to an iPod. Just want to see if it's a good deal for $40 shipped.
Did anyone reformat the drive after you got it? Does it still reports the stated capacity afterwards? There have been scams going around with NAND chips marked at half capacity being sold as full.
Took less than 10 calendar days to receive mine.
I like the Glacier, however, I'm having trouble navigating between folders on the device. I can fast forward enough where it changes folders, but I really don't like doing that thru 500 songs. I read somewhere on it it has a limitation of 99 folders. Can anyone confirm?
PS. Uxcel LED flashlights are AWESOME for the price. Got mine same day as my glacier. The light is BRIGHT as hell. and thats just in the day time.
Folder navigation is easy but not intuitive.
When you are on a song (or video) ready to play (but not when playing) just hit the "M" button. You will get a menu and the "Local Folders" (or something similar) is ready to select. Select with the "M" button and you are now in folder navigation mode. Use "<<" and ">>" to move up and down. the "\" menu item will take you up a level when you press "M" on it. Pressing "M" while on a folder will navigate down into the folder.
You must end by pressing "M" on a song. This will throw you back to the ready to play mode with a new song ready and your folder position changed. If you wait too long the navigation mode times out and you go back where you started.
Pressing the "M" button while playing songs gets you to the EQ and repeat settings.
