Graphite 380T with two AIO?
HyperionX
I'm thinking of a geforce 980 GTX with a AIO using the NZXT G10 GPU bracket. with a corsair H110 placed on the side of the case.
And then an i7 with a H90 with the radiator on the back, because i want to put a 200mm fan up front.
So my question to all those that had experience with the case, or those who don't. Can I fit two radiators in there?
I have seen two 120mm fans side by side in the front of the case, but i don't know if you can put a 240mm radiator in the front.
You can 240mm on the side and 120mm on the rear at the same time with plenty of room. But 280mm / 140mm combo, unfortunately, won't work. The side will only support up to 240 rad and the rear up to 120mm spec rad.
Largest fan you can put in the front is 200mm.
Thanks for the information. this means i would go with the H80i and the H100i from corsair.
if that's the case then there's a problem because the NXZT bracket for GPU doesn't support those coolers.
Does anyone know if there is a bracket out there that would work with those AIOs?
You could go with the thermal take water extreme s if you want dual 120's. I also think there is the corsair hg10 which take the other types of coolers. Personally I like the nzxt kraken, but it was a pain to get seated correctly on my radeon 290x's.
