- Jan 27, 2003
I have noticed that the PCI express slot mounting screws and the case do not exactly line up. In the past I have 'forced it' which has the effect of letting me screw the card into place but shifts it withing the PCI-express slot.
Graphics Card - will screw in but shifts within PCIexpress slot
Lan card - I couldn't even use several of the ports because when I screwed it down it would pull some pins out of the PCI slot.
In a last ditch effort to bring about stability, I unscrewed my Radeon 5850 and set the case flat on the desk to take the pressure off. So far I've been running prime95 without a hitch for over an hour.
Has anyone else run into this?
Should I ever try to screw it down?
Should I mod the video card so I can tighten the screws?
I trusted Antec in the past; are there cases with better dimensions/squareness?
I was debating zip-tiing it in place, I think the main point of screwing down the card is to take pressure off the PCI express slot.
Check out pics:
Check out pics:
