graphics problems win8.1 9800gtx
stunning
Just updated my pc to windows 8.1 and I am having graphic problems.
When I launch dota2, everything seems to be normal until i get into the game. While in game the characters are not visible, they are clear mirages or sparkling images.
Im on the latest drivers from nvidia. 340.52
Uninstall the drivers, use DDU, reinstall drivers.
If that doesn't work then try a previous version.
What OS did you come from when upgrading to 8.1? Did you do a clean or upgrade install?
finally figured it out. It was the 3D setting that gets installed when you select all the defaults.
thanks for everyones suggestions.
