Alright, I've been having troubles with graphics card in my Motherboard. Let me explain a bit. I bought a e-geforce 8400 gs. I play old games, nothing to knew so i was fine with that purchase. Anywho, It is a pci-e x 16 xard, so i put it in the slot. I made sure to change the slot in the bios to pci-e x 16. I then changed the cable to that and started it up, however the monitor does not detect the card at all. I get a black screen saying nothing is connected. I go into device manager and still nothing.
This is my pc.
http://h10025.www1.hp.com/ewfrf/wc/...18&lc=en&dlc=en&cc=us&product=3577836&lang=en
http://h10025.www1.hp.com/ewfrf/wc/...48&lc=en&dlc=en&cc=us&product=3577836&lang=en
After talking with tec support, I purchased a 600 watt power supply. Still the same problem. After months i just stuck with my integrated 6150 se nforce 430. However, now i wish to order parts to build a new pc.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.203013
So my question is, was it the graphics card that was the problem or my mother board?
This is my pc.
