Graphics card that uninstalls itself.....?
skunkmunkey
Hi,
Until now my pc has worked fine. When all of a sudden each time i reboot my 7800 gtx uninstalls itself. It works fine once the drivers have been re-installed but its a real pain to do each time.
I have tried all sorts of drivers but that doesn't help and have messed around with the bios settings of my mobo etc... I really would rather not format my pc as its such a hassle to back-up all my stuff. Anyone have any idea how i can solve this prob?
BTW I have: XFX 7800gtx (using 91.47 driver), core 2 duo e6600 and Asus P5W-DH Deluxe (with latest bios)
Something sounds fishy.... have you run an Anti-Virus and mal/spyware application yet? (in safe mode please!)
I had a client that had her Windows box load generic drivers for her videocard... made the system lag pretty badly (screen studder), then I realized heresystem was using generic drivers instead of the ATI drivers it should ave been using. Turned out her system was INFESTED with spyware (pest patrol and spybot found over 2200 items) and one virus. Rather than trying to clean her system, we backed up HER DATA (which all fit on my 1GB flash drive), and reformatted and re-installed XP. Video issues resolved.... until she starts surfin those questionable website again. :rolleyes:
Post your entire computer specs, including power supply and components.
It could be a power issue, but cannot tell with what you have told us.
ok my full specs are:
Intel E6600 (std speeds atm)
Asus P5W DH Deluxe (latest bios)
XFX Ge force 7800gtx (91.47)
550 watt Hiper Type-R PSU
Corsair XMS 2 8500 Ram (4-4-4-14 @ 1066mhz)
2 x WD 74gb Raptor (raid)
Creative X-FI FATAL1TY sound
Plextor PX71AL dvd-RW
Windows XP home (fully updated)
Kaspersky Anti virus (updated)
Spybot & Ad-Aware (updated)
Diskeeper Pro V10
the weird thing is its just happened. my Pc went weird and wouldn't start or let me install Xp. So i went to bed. Next morning it worked fine, until reboot when it lost drivers and used standard xp drivers (does the weird stutter thing on web pages).
Once i have re-installed drivers it works fine and i can play games etc provided I don't restart the pc. I have also noticed that i cannot get to the display properties now either, i can get to the first screen where i can change resolution but i cant access any of the advanced options or the NV control panel, the tabs have just gone.....
Things to try:
Check in the CMOS that it is set to Plug & Play OS and IRQ control is set to Auto.
If that isnt it, reset the CMOS, it could be corrupt.
Uninstall the drivers for the graphics card and the motherboard then run Driver Cleaner Pro to remove all traces left behind.
http://www.softpedia.com/reviews/windows/Driver-Cleaner-Professional-Review-33638.shtml
(Read the review on that page as well which explains to use caution)
Home page:
http://www.drivercleaner.net/
Reboot and reinstall the motherboard drivers and then the video driver.
This is a small step that you might not want to be that bothered with but if it is only a bad connection you'll kick yourself later :)
Unplug the power connectors, memory and all cards, make sure the connectors are clean and there are no bent pins.
Plug it all back in and test.
Good luck :)
lol yea.... none of the other things have worked so im off to buy a chicken....
Looks like its format time again.... don't you hate having to phone Microsoft to activate your windows.... (i didn't buy my copy... got a liscence off a dead pc where i used to work)
the chciken will work better and taste better after the ritual sacrifice if you use some shake n' bake
