Hey everyone, I moved my system into a new case and reinstalled Windows earlier this week. Ever since then, any sort of graphic intensive activity like full screen visualizations (Specifically Electric Sheep), movies, 3d benchmarks, etc., cause my dual 22" displays to go black and give the "No input signal" message. If I'm playing audio, the audio continues for about 1 minute. The computer doesn't really crash per se, the fans keep whirring like nothing happened. Just listening to the computer I wouldn't be able to tell a difference (except for the audio stopping). When I restart I get the typical "Windows was not properly shut down" menu.
Here is my hardware setup:
Windows 7 x64
AMD Athalon64 x2 4400+ (2.2GHz dual core, no OC)
DFI Lan Party nForce 4 SLI-DR
4x1 GB DDR-400 RAM (Runs at DDR-333 speeds)
Sapphire ATI 4670 Graphics Card (Passive cooler, no OC)
2 22" Acer widescreen displays
Enermax 600W PSU
5x SATA HDDs
1x SATA DVD burner
Drivers:
Catalyst 9.11 and 9.10
nForce 15.23
Realtek AC97 audio driver
Using the testing program "Burn In Test" tells me a few things:
1) It's not the CPU, the CPU tests all pass
2) It's not the RAM
3) The 3D Graphics test almost instantly fails (However it does not cause a crash)
4) The Graphics RAM test passes after I went from Catalyst 9.11 to 9.10
5) Turning all the fans on max doesn't help the situation (In other words, I don't think it's an overheating issue)
So I figure it must be the video card since I can stress test everything else and it is fine but a simple video playing back will cause this crash. As the cooler is passive, and I moved into a case with more fans and better cooling, and speedfan doesn't tell me that anything is overheating, I don't think it's an overheating issue.
I switched to Catalyst 9.10 to see if that resolved anything, and it didn't seem to.
I'm trying to avoid a reinstall of Windows and certainly avoid buying a new graphics card.
Any help would be much appreciated!
Windows 7 x64
Enermax 600W PSU
5x SATA HDDs
1x SATA DVD burner
Drivers:
nForce 15.23
2) It's not the RAM
